- To:
- Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
- Date: Wed, 13 Sep 2017 14:10:49 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:9QX4pRK6QQaJesNYudmcpTZWNBhigK39O0sv0rFitYgXIvjxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUdExG6OQtuLfnuAabTid623qa84c79eQJN0XCGbLl7Nwm3oAOZks4MgIx+YuYexxzMr2dSaspfzn9vP0PS1V6o/cO35p9k72JVv9ou8sdBVePxeKFuHu8QNygvL21gvJ6jjhLEVwbavnY=
On 09/13/2017 01:32 PM, Iasonm wrote:
No I did not, but the thing is that a skeleton is not a 2-manifold surface
right? So maybe that's why edge_collapse was not used here
<https://github.com/CGAL/cgal/blob/master/Surface_mesh_skeletonization/include/CGAL/internal/Surface_mesh_skeletonization/Curve_skeleton.h>
. Maybe I should use a similar approach. Is there any doc regarding
Curve_skeleton.h or any document that describes its implementation (besides
the source code)?
If you're talking about the final step when the meso-skeleton is turned into a curve-skeleton, then indeed collapse_edge is not used and
the FaceGraph model is no longer used (another data structure is used
for collapsing those edges). I think this step is explained in a former
paper:
A U O. K.-C., T AI C.-L., C HU H.-K., C OHEN -O R
D., L EE T.-Y.: Skeleton extraction by mesh contraction. ACM
Transactions on Graphics (Proc. of SIGGRAPH) 27, 3 (2008)
HTH
Sebastien.
Best Regards,
Iason
- [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 09/07/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/09/2017
