- To:
- Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh
- Date: Thu, 07 Sep 2017 10:29:12 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:wrOGKBHUb9WY1JFYdBvGm51GYnF86YWxBRYc798ds5kLTJ76rsywAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTx7wPA4wKuXuEZPJlOy20fqz8tvdeVZmnj24NPlWJQisoAPN/vMXh4ZrN+5x4TTghjxnduNTyH9yNHyalAr7/NbxttY39y1Nof8n64haUKP3drkQRrNRCHIhKW9jt56jjgXKUQbavihUaW4RiBcdWwU=
Le Wednesday, September 6, 2017 3:32:12 PM CEST Iasonm a ?crit :
> Hello,
> I have some questions regarding the use of collapse_edge on a surface_mesh.
> *Why I need it*
> I am implementing this
> <http://visgraph.cse.ust.hk/projects/skeleton/skeleton_sig08.pdf> for
> educational purposes.
Hi,
Once you have implemented that method, you can compare the results with the
skeletonization that is in CGAL:
https://doc.cgal.org/latest/Surface_mesh_skeletonization/index.html
It is based on another paper, published four years later:
http://ialhashim.github.io/files/documents/tag_sgp12.pdf
- [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/11/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Sebastien Loriot (GeometryFactory), 09/13/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 09/07/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge use on CGAL::Surface_mesh, Iasonm, 09/09/2017
