cgal-discuss - Re: [cgal-discuss] CGAL_assertion: identifier not found
  • To:
  • Subject: Re: [cgal-discuss] CGAL_assertion: identifier not found
  • Date: Fri, 15 Jun 2018 13:22:43 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
mesh=?
You are probably missing a default property map. With Surface_mesh it should be working out of the box.
Sebastien.
On 06/15/2018 12:30 PM, sergio wrote:
Adding to my code this line:
bool solved =
CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
I get the error:
"CGAL_Assertion: identifier not found"
And after check it i found the line 489 of property_map.h
CGAL_assertion(pm.set_ptr!=NULL);
Some definition is missing. What wrong?
