- To:
- Subject: Re: [cgal-discuss] CGAL_assertion: identifier not found
- Date: Fri, 15 Jun 2018 14:18:51 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Friday, June 15, 2018 12:30:22 PM CEST sergio a ?crit :
> Adding to my code this line:
> bool solved =
> CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
> I get the error:
> "CGAL_Assertion: identifier not found"
> And after check it i found the line 489 of property_map.h
> CGAL_assertion(pm.set_ptr!=NULL);
> Some definition is missing. What wrong?
Try add
#include <CGAL/assertions.h>
in the list of includes at the beginning of <CGAL/property_map.h>. It seems
to be missing.
Laurent Rineau, PhD
- [cgal-discuss] CGAL_assertion: identifier not found, sergio, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, Sebastien Loriot (GeometryFactory), 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, sergio campo, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, sergio, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, Laurent Rineau (CGAL/GeometryFactory), 06/15/2018
