- To:
- Subject: Re: [cgal-discuss] CGAL_assertion: identifier not found
- Date: Fri, 15 Jun 2018 14:04:53 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I have no crystal ball, I cannot guess what version of CGAL you are using. If you want some help please be precise. It is compiling with my
setting with master and CGAL 4.12
Sebastien.
On 06/15/2018 01:51 PM, sergio wrote:
It doesn't work with
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Surface_mesh<Kernel::Point_3> Mesh;
Mesh mesh;
bool solved = true;
solved =
CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
- [cgal-discuss] CGAL_assertion: identifier not found, sergio, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, Sebastien Loriot (GeometryFactory), 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, sergio campo, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, sergio, 06/15/2018
- Re: [cgal-discuss] CGAL_assertion: identifier not found, Laurent Rineau (CGAL/GeometryFactory), 06/15/2018
