cgal-discuss - Re: [cgal-discuss] CGAL_assertion: identifier not found
  • To:
  • Subject: Re: [cgal-discuss] CGAL_assertion: identifier not found
  • Date: Fri, 15 Jun 2018 13:27:30 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
Polyhedron mesh I will change it forĀ  Surface_mesh
On Fri, Jun 15, 2018 at 1:22 PM, Sebastien Loriot (GeometryFactory) <> wrote:
mesh=?
You are probably missing a default property map. With Surface_mesh it should be working out of the box.
Sebastien.
On 06/15/2018 12:30 PM, sergio wrote:
Adding to my code this line:
bool solved =
CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
I get the error:
"CGAL_Assertion: identifier not found"
And after check it i found the line 489 of property_map.h
CGAL_assertion(pm.set_ptr!=NULL);
Some definition is missing. What wrong?
