- To:
- Subject: Re: [cgal-discuss] linking error
- Date: Mon, 9 Jul 2018 17:41:10 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Could you describe the steps you did to use the header only version
and when did you get the error message?
I clicked headeronly verion in cmake-gui, clicked to configure, clicked to generate, clicked to
open project and used Erstellen (Create) -> something_forgotten erstellen.
The errormessage i got when i try to link the application using cgal (white_dune).
so long
MUFTI
- [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/10/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/11/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/11/2018
