cgal-discuss - Re: [cgal-discuss] linking error
  • To:
  • Subject: Re: [cgal-discuss] linking error
  • Date: Mon, 9 Jul 2018 17:52:56 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Could it be that you already configured CGAL in-source?
Actually, starting from CGAL 4.12, when you have a fresh extracted CGAL,
you can directly use it without having to call cmake on it, like it is
described here:
https://doc.cgal.org/latest/Manual/installation.html#title16
by directly configuring the project using CGAL that you want to build.
Sebastien.
On 07/09/2018 05:41 PM, j. scheurich wrote:
Could you describe the steps you did to use the header only version
and when did you get the error message?
I clicked headeronly verion in cmake-gui, clicked to configure, clicked to generate, clicked to
open project and used Erstellen (Create) -> something_forgotten erstellen.
The errormessage i got when i try to link the application using cgal (white_dune).
so long
MUFTI
