- To:
- Subject: Re: [cgal-discuss] linking error
- Date: Tue, 10 Jul 2018 12:30:27 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I use the headerfile only version of cgal 4.12 with visual c++ 2017 community.
i got the following linking errror:
>LINK : fatal error LNK1104: Datei "libCGAL-vc140-mt-gd-4.12.lib" kann nicht geƶffnet werden.
...can't be opened
Now understand: "header only" version of CGAL do not mean, there are only headerfiles (like in vcglib).
"header only" version means: the linking command is in a special pragma in the hederfiles (like in boost).
"libCGAL-vc140-mt-gd-4.12.lib" is really needed.
so long
MUFTI
- [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/10/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/11/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/11/2018
