cgal-discuss - Re: [cgal-discuss] linking error
  • To:
  • Subject: Re: [cgal-discuss] linking error
  • Date: Tue, 10 Jul 2018 11:24:16 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Am 09.07.2018 um 17:52 schrieb Sebastien Loriot (GeometryFactory):
Could it be that you already configured CGAL in-source?
Actually, starting from CGAL 4.12, when you have a fresh extracted CGAL,
you can directly use it without having to call cmake on it, like it is
described here:
https://doc.cgal.org/latest/Manual/installation.html#title16
by directly configuring the project using CGAL that you want to build.
C:\cygwin64\home\mufti\CGAL-4.12>cmake -DCGAL_DIR=C:\cygwin64\home\mufti\CGAL-4.12
-- Build CGAL from release in directory CGAL-4.12
-- Packagenames: CGAL-4.12
== Setting paths (DONE)
==== Generate version files ==
CMake Error at CMakeLists.txt:252 (message):
 File VERSION or include/CGAL/version.h are missing, required by
  release-build.
-- Configuring incomplete, errors occurred!
See also "C:/cygwin64/home/mufti/CGAL-4.12/CMakeFiles/CMakeOutput.log".
Lets try wth libraries...
so long
MUFTI
