cgal-discuss - Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
  • To:
  • Subject: Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
  • Date: Fri, 6 Sep 2019 06:19:02 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
You need to give more details. What data structure of CGAL are you using
for your multi-label mesh?
If you are using property maps, the free function get(map, v) will return the value associated to the vertex v.
Sebastien.
On 9/5/19 6:15 PM, Shrabani Ghosh wrote:
Hi,
In a multi-label mesh, I need to know which vertex has what label value. I
tried with properties of vertex but I cannot fetch the existing label value.
How can I do that?
Regards
Shrabani Ghosh
