- To:
- Subject: Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
- Date: Tue, 10 Sep 2019 14:11:26 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Thank You for your response. Later I understood that I have to label
actually. Now it's working.
I want to use color so that I can visualize different label values is
labeled properly. Is there anything in CGAL to visualize different colored
mesh?
Thanks in advance.
Regards
Shrabani
- [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/05/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/06/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/07/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/09/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/09/2019
- [cgal-discuss] ?????? [cgal-discuss] How can I fetch the label value of a meshvertices?, ????, 09/09/2019
- Re: [cgal-discuss] 回复: How can I fetch the label value of a meshvertices?, Shrabani Ghosh, 09/10/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/10/2019
