- To:
- Subject: Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
- Date: Mon, 9 Sep 2019 07:03:17 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I think the error says that the property does not exist. If you already
created it then there is a pb somewhere. Maybe you operate on another
mesh, added the property on a temporary mesh (did you take the mesh by copy instead of by reference?)...
Sebastien.
On 9/9/19 6:56 AM, Shrabani Ghosh wrote:
But the voxel label value information is already in the triangular mesh. When
I generated the triangular surface mesh from the 3D image, I already kept
the vertex material information in the surface mesh. Now I just need to
fetch the material information. Do I again need to add property?
Regards
Shrabani
- [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/05/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/06/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/07/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/09/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/09/2019
- [cgal-discuss] ?????? [cgal-discuss] How can I fetch the label value of a meshvertices?, ????, 09/09/2019
- Re: [cgal-discuss] 回复: How can I fetch the label value of a meshvertices?, Shrabani Ghosh, 09/10/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/10/2019
