- To:
- Subject: Re: [cgal-discuss] 回复: How can I fetch the label value of a meshvertices?
- Date: Tue, 10 Sep 2019 14:08:49 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Thank You for your response. Later I understood that I have to label
actually. Now it's working.
- [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/05/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/06/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/07/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Sebastien Loriot (GeometryFactory), 09/09/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/09/2019
- [cgal-discuss] ?????? [cgal-discuss] How can I fetch the label value of a meshvertices?, ????, 09/09/2019
- Re: [cgal-discuss] 回复: How can I fetch the label value of a meshvertices?, Shrabani Ghosh, 09/10/2019
- Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?, Shrabani Ghosh, 09/10/2019
