- To:
- Subject: Re: [cgal-discuss] Eroormessage of CSG cut
- Date: Thu, 12 Mar 2020 10:03:15 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Honestly, how do you expect to get a helpful reply to this kind of message.
Please provide a self contained example on gist.git.com together
with
a small data set where you get the exception, so that we can try
to
reproduce/analyze/fix
Best,
Andreas
On 3/12/2020 7:15 AM, J. Scheurich
wrote:
Hi, When i try to use CGALS's CSG cut, i get the following exception: CGAL exception: tm_to_output_edges.count(h, tm, tm)) != 0 What does this mean ? so long MUFTI
-- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Andreas Fabri, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Sebastien Loriot (GeometryFactory), 03/13/2020
