- To:
- Subject: Re: [cgal-discuss] Eroormessage of CSG cut
- Date: Thu, 12 Mar 2020 16:27:18 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:2mcCsBGg9h/vU5ILS0nEfZ1GYnF86YWxBRYc798ds5kLTJ75psuwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQMUAQj1YAppOvzuSMmVlNWyz+n0+pvJYgwOiiD6eqJ3NBzxrAPfsY4djoJmb6ow0RDUuWAbR+MDzmxhIRefng33+9yr1J9l6SVZ/fw7pOBaVqCvWq0oTLlVRBsnNm0z44W/sBDTTA6CoHQdV2gQlTJHBgHE6FfxWZKn4XiyjfZ0xCTPZZ6+drszQzn3t/46Gi+tsz8OMnsCyE+Sj8VxiKxBpxf4/k5wxofVZMeeM/8sJ/qAL+NffnJIW4NqbwIEAo64aNFRXe8IPOIdqIik4lVX8kX4Cg6rC+fijDRPgy2uhPFo46EaCQjDmTcYMZcWqn2N9Yf6Ma4TVaa+y6yalTg=
Also, this input is not a valid surface mesh, as it dreams to have orientation problems. This is probably the origin of the exception.
Meshlab is able to read the off because it ignores the N blahblah lines, which your CGAL version does not. Where did you find that off ?
On 12.03.20 10:03, Andreas Fabri wrote:
> Honestly, how do you expect to get a helpful reply to this kind of
> message.
> Please provide a self contained example on gist.git.com together with
> a small data set where you get the exception, so that we can try to
> reproduce/analyze/fix
The test program is at
http://wdune.ourproject.org/examples/reduced.cpp
but the mesh .off data of
http://wdune.ourproject.org/examples/reduced1.off
can not be read by cgal (another bug ?), while meshlab can read it.
To view the execption, you can use white_dune (open source, but needs a lot
of libraries), there is a binary for MSWindows 10, MacOSX, Ubuntu LINUX,
Arch Linux,
OpenSuse Linux and Debian Linux. It is also part of fedora 33.
Run
$ dune http://wdune.ourproject.org/examples/cgal_test.x3dv
and click to Group and then use Indexed(Face)Set -> boolean operations
-> cut
so long
MUFTI
- [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Andreas Fabri, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Sebastien Loriot (GeometryFactory), 03/13/2020
