- To:
- Subject: Re: [cgal-discuss] Eroormessage of CSG cut
- Date: Thu, 12 Mar 2020 16:00:06 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:5+AQNh2mWu3fOYK8smDT+DRfVm0co7zxezQtwd8ZsesTLPad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jEbHlDzNBF+O//uMo/UlcW+ke6oqLPJZAAdzhj7KYh5LBirtwTatoNe1Y5/JLowk0LhvXZCPehbkzA7bWmPlgrxs5/jtKVo9D5d7qp4qpxwFJ7idqF9doR2STQrN2dsv5/usgTfCxSC7D0QXzdOy0YaM03+9Bj/G6zJnG7irOMtijaXN4v6QOJsAGXw3+JQUBbtzRw/GXs8+WDThNZ3ifIJvx+r4RBykdfZ
On 12.03.20 10:03, Andreas Fabri wrote:
> Honestly, how do you expect to get a helpful reply to this kind of
> message.
> Please provide a self contained example on gist.git.com together with
> a small data set where you get the exception, so that we can try to
> reproduce/analyze/fix
The test program is at
http://wdune.ourproject.org/examples/reduced.cpp
but the mesh .off data of
http://wdune.ourproject.org/examples/reduced1.off
can not be read by cgal (another bug ?), while meshlab can read it.
To view the execption, you can use white_dune (open source, but needs a lot
of libraries), there is a binary for MSWindows 10, MacOSX, Ubuntu LINUX,
Arch Linux,
OpenSuse Linux and Debian Linux. It is also part of fedora 33.
Run
$ dune http://wdune.ourproject.org/examples/cgal_test.x3dv
and click to Group and then use Indexed(Face)Set -> boolean operations
-> cut
so long
MUFTI
- [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Andreas Fabri, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Sebastien Loriot (GeometryFactory), 03/13/2020
