- To:
- Subject: Re: [cgal-discuss] Eroormessage of CSG cut
- Date: Thu, 12 Mar 2020 16:56:45 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Meshlab is able to read the off because it ignores the N blahblah
lines, which your CGAL version does not. Where did you find that off ?
The .off files has been writen by white_dune. white:dune can triangulate
meshes and the normal lines
can be deleted in a editor.
I will change the test data.
thanks
so long
MUFTI
- [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Andreas Fabri, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Sebastien Loriot (GeometryFactory), 03/13/2020
