- To:
- Subject: Re: [cgal-discuss] Eroormessage of CSG cut
- Date: Thu, 12 Mar 2020 16:06:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:OTlVpxO9E6/TzFi/U+0l6mtUPXoX/o7sNwtQ0KIMzox0KP38rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWP6yUPEED/KRZtPbayXZXDity+keG04ZzaJQtSwyGsZKt7axSwowKWvcYfhc5uK7061wDS8UdPLu9ZzGctKVOIlAvn/e+x+oRi+mJeoaEP7clFBIDzb6U9QPR3DTErNWd9sMjipRjGQE2A534RVGI+nR9BAgyD5xb/CMSi+hDmv/ZwjXHJdfb9Sqo5DGz7svVbDSTwgSJCDAYXtWHajssq0vBeqROl4ht+msvaOd7OcvV5eazZcJURQm8TBp8NBRwEOZu1as40N8REJfxR9tCvqF4HrB/4Dg6pVru2m214w0Tu1Kh/6NwPVATP3QguBdUL6S2Go9D8NaNUWuewnvDF
Meshlab is able to read the off because it ignores the N blahblah lines, which your CGAL version does not. Where did you find that off ?
On 12.03.20 10:03, Andreas Fabri wrote:
> Honestly, how do you expect to get a helpful reply to this kind of
> message.
> Please provide a self contained example on gist.git.com together with
> a small data set where you get the exception, so that we can try to
> reproduce/analyze/fix
The test program is at
http://wdune.ourproject.org/examples/reduced.cpp
but the mesh .off data of
http://wdune.ourproject.org/examples/reduced1.off
can not be read by cgal (another bug ?), while meshlab can read it.
To view the execption, you can use white_dune (open source, but needs a lot
of libraries), there is a binary for MSWindows 10, MacOSX, Ubuntu LINUX,
Arch Linux,
OpenSuse Linux and Debian Linux. It is also part of fedora 33.
Run
$ dune http://wdune.ourproject.org/examples/cgal_test.x3dv
and click to Group and then use Indexed(Face)Set -> boolean operations
-> cut
so long
MUFTI
- [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Andreas Fabri, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/12/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Maxime Gimeno, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, J. Scheurich, 03/13/2020
- Re: [cgal-discuss] Eroormessage of CSG cut, Sebastien Loriot (GeometryFactory), 03/13/2020
