cgal-discuss - Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • To:
  • Subject: Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • Date: Tue, 16 Jun 2020 08:58:27 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
There is a mistake in the doc you are reading, the cgal-qt5 formula was not accepted by brew and therefore it doesn't exist. The Qt components were recently incorporated in the `cgal` formula (https://github.com/Homebrew/homebrew-core/pull/52462), So as long as you have qt5 installed via brew in your system it should be installed without further option.
Le lun. 15 juin 2020 à 23:06, Himanshu Sharma <> a écrit :
Hello,
I am using Catalina Version 10.15.2. I wish to run cgal - qt examples. However while installing cga-qt5 using brew, I run into the following error:
"No available formula with the name "cgal-qt5" "
I could not find any documentation on how to resolve this issue.
Regards
