cgal-discuss - Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • To:
  • Subject: Re: [cgal-discuss] No available formula with the name "cgal-qt5"
  • Date: Wed, 24 Jun 2020 09:23:23 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
Did you configure the example with cmake ? Did you specify a path to the Qt5 directory ? Can we see your CMakeCache.txt file, generated in your build directory ?
Le mar. 23 juin 2020 à 19:41, Himanshu Sharma <> a écrit :
Thanks for your reply.
I do have qt installed in brew environment. However when I try to compile examples in Triangulation_2, and I get the error message:
NOTICE: The example draw_triangulation_2 requires Qt and will not be compiled.
Have attached the screenshot, if it helps.
Regards
Himanshu
On Wed, Jun 17, 2020 at 11:24 AM Laurent Rineau (CGAL/GeometryFactory) <> wrote:
On Monday, June 15, 2020 11:05:27 PM CEST Himanshu Sharma wrote:
> Hello,
> I am using Catalina Version 10.15.2. I wish to run cgal - qt examples.
> However while installing cga-qt5 using brew, I run into the following error:
> *"No available formula with the name "cgal-qt5" "*
> I could not find any documentation on how to resolve this issue.
> Regards
The review process in homebrew has decided to remove that package cgal-qt5. It
is sufficient to install `cgal` and `qt` in homebrew, to get the features of
CGAL_Qt5.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
