coq-club - Re: [Coq-Club] relevance of evaluating accessibility arguments
chronological Thread
  • From: Jean-Francois Monin <jeanfrancois.monin AT rd.francetelecom.com>
  • To: coq-club AT pauillac.inria.fr, Pierre Courtieu <Pierre.Courtieu AT sophia.inria.fr>
  • Cc: Jean-Francois Monin <jeanfrancois.monin AT rd.francetelecom.com>
  • Subject: Re: [Coq-Club] relevance of evaluating accessibility arguments
  • Date: Wed, 20 Nov 2002 13:04:35 +0100
I just want Eval Compute (flog O (all_acc_div2 O)) to provide the result.
After all, STRONG normalization is not crucial here (and may be
overestimated or misleading).
As Extraction is supposed to work, Coq should be able to perform
the evaluation of (flog O (all_acc_div2 O)) without computing
(all_acc_div2 O). In other words, common strategies like Lazy
and preferably CBV should not have the pathological behavior you mention.
Is there any result on this topic?
  Jean-Francois
Pierre Courtieu wrote:
 > Suppose you allow the Fix to be reduced in the term:
 > (flog O (all_acc_div2 n)).
 > You obtain:
 > Cases (test_O_1_else O) of
 >    | (C0 _) => O
 >    | (C1 _) => O
 >    | (C2 p) => (S (flog (div2 O) (inv_acc_div2 O a p)))
 > end.
 > and then you can reduce (div2 O) into O:
 >    | (C0 _) => O
 >    | (C1 _) => O
 >    | (C2 p) => (S (flog O (inv_acc_div2 O a p)))
 > end.
 > and then you can reduce again the Fix infinitely ! You lost SN. This
 > seems to be a consequence of Fix/Case duality.
