- From: Benjamin Werner <werner AT pauillac.inria.fr>
- To: jeanfrancois.monin AT rd.francetelecom.com (Jean-Francois Monin)
- Cc: Judicael.Courant AT lri.fr, jeanfrancois.monin AT rd.francetelecom.com, Pierre.Courtieu AT sophia.inria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] relevance of evaluating accessibility arguments
- Date: Wed, 20 Nov 2002 16:11:52 +0100 (MET)
Hi Jean-Francois, hi everyone,
This is an old debate. This question appeared a while ago in the coice
between what Per Martin-Lof called extentional, resp. intentional,
type theories. The latter uses the conversion rule as we know it (with
variants of beta-conversion) in the first, the beta-conversion
side-condition is replaced by Leibniz equality.
It is easy to see that in an incoherent context one can prove A = A->A
and thus type any term in an extentional theory.
The situation is simillar here with the Acc-rec, even if not so
extreme.
In both cases however, strong normalization is broken and thus
(theoretical) decidability of type-checking.
More generaly, it appears that :
* computational terms (of sorts Set, Type) can depend upon
non-computational proofs through three constructs: False_rec, eq_rec
and Acc_rec (and their _rect counterparts).
* False_rec poses no problem, since there is no computation rule
associated to it.
* eq_rec could be handled using a trick Christine mentioned a while
ago, since only conversion of the two parts of the equality is
involved, which is decidable.
* acc_rec is more tricky. I do not know of a totaly satisfactory
solution which would come in handy.
My main question is whether the reduction of acc_rec is actualy used
to a large extent, of if one will want to use it (for other means than
proving the corresponding equality lemmas).
Up to now, I was tending to think that what we be gained from this was
not worth breaking strong normalization (and also making
efficient/compiled reduction much more difficult).
I would be interested in any opinions on this topic.
Best wishes,
Benjamin
> OK, but what is the point to enforce normalisation in an inconsistent
> context? One of the main uses of normalisation is to ensure
> consistency.
> Best,
> JF
> > If you add an inconsistent axiom such as
> > Axiom wf : (x:A)(accessible x).
> > and if you remove the head-constructor condition for the decreasing
> > argument, then you can build terms that have no normal form:
> > (f a (wf a)) here.
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] relevance of evaluating accessibility arguments, Jean-Francois Monin
- Re: [Coq-Club] relevance of evaluating accessibility arguments,
Pierre Courtieu
Randy Pollack
- lRe: [Coq-Club] relevance of evaluating accessibility arguments,
Eduardo Gimenez
Jean-Francois Monin
- Message not available
- Re: [Coq-Club] relevance of evaluating accessibility arguments, Jean-Francois Monin
Jean-Francois Monin
Eduardo Gimenez
Jean-Francois Monin
Judicael Courant
Jean-Francois Monin
- Re: [Coq-Club] relevance of evaluating accessibility arguments, Benjamin Werner
Jean-Francois Monin
Judicael Courant
Randy Pollack
Nicolas Magaud
Venanzio Capretta
Venanzio Capretta
Pierre Courtieu
