coq-club - Re: [Coq-Club] relevance of evaluating accessibility arguments
chronological Thread
  • From: Venanzio Capretta <Venanzio.Capretta AT sophia.inria.fr>
  • To: Nicolas Magaud <Nicolas.Magaud AT sophia.inria.fr>
  • Cc: Jean-Francois Monin <jeanfrancois.monin AT rd.francetelecom.com>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] relevance of evaluating accessibility arguments
  • Date: Thu, 21 Nov 2002 10:12:34 +0100
  • Organization: INRIA Sophia Antipolis
Hi,
  here is the trick that I use to "compute" functions defined with an
accessibility predicate in Coq: Since for every argument there is only
one constructor of the accessibility predicate that can be applied, you
can generate the proof of accessibility automathically:
fAcc: A -> Set
f: (x:A)(fAcc x) -> B.
To compute (fAcc a) for a specific a, first generate automatically the
proof of (fAcc a):
Definition ha:(fAcc a).
  Repeat Constructor.
Defined.
Eval Compute in (f a ha).
You can also prove and compute at the same time:
Definition result: B.
  Apply (f a).
  Repeat Constructor.
Defined.
Eval Compute in result.
EXAMPLE:
Require Arith.
Fixpoint div2 [n:nat]: nat:=
Cases n of
  O => O
| (S O) => O
| (S (S n)) => (S (div2 n))
end.
f 0 = 1
f n+1 = n*(f (div2 n))
Inductive fAcc: nat -> Set:=
  facc0: (fAcc O)
| faccS: (n:nat)(fAcc (div2 n))->(fAcc n).
Fixpoint f [n:nat; h:(fAcc n)]: nat:=
Cases h of
  facc0 => (S O)
| (faccS n h) => (mult n (f (div2 n) h))
end.
Definition fAcc10: (fAcc (10)).
Repeat Constructor.
Defined.
Eval Compute in (f (10) fAcc10).
Definition result: nat.
Apply (f (10)).
Repeat Constructor.
Defined.
Bye,
  Venanzio
