coq-club - Re: [Coq-Club] relevance of evaluating accessibility arguments
chronological Thread
  • From: Judicael Courant <Judicael.Courant AT lri.fr>
  • To: Jean-Francois Monin <jeanfrancois.monin AT rd.francetelecom.com>
  • Cc: Pierre Courtieu <Pierre.Courtieu AT sophia.inria.fr>, Jean-Francois Monin <jeanfrancois.monin AT rd.francetelecom.com>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] relevance of evaluating accessibility arguments
  • Date: Wed, 20 Nov 2002 14:58:52 +0100
Le 2002.11.18 14:12, Jean-Francois Monin a écrit :
Beware: my problem is not in the definition of the fixpoint
but in its use.
Sure, but that is also what Pierre suggests I think.
I hope the following example will help:
Variable A : Set.
Variable a : A.
Inductive accessible : A -> Prop := C : (x:A)(accessible x)->(accessible x).
Fixpoint f [x:A; a:(accessible x)] : nat :=
(S (f x (<[a0:A](accessible a0)>Cases a of (C x0 H) => H end))).
The above definition is ok: thanks to the head-constructor condition, (f x (C^n H)) will reduce to (S^n (f x H)).
Eval Compute in (C a (wf a)).
Eval Compute in (f a (C a (wf a))).
Eval Compute in (f a (C a (C a (wf a)))).
If you add an inconsistent axiom such as
Axiom wf : (x:A)(accessible x).
and if you remove the head-constructor condition for the decreasing argument, then you can build terms that have no normal form:
(f a (wf a)) here.
Best,
Judicaël.
Judicael.Courant AT lri.fr,
 http://www.lri.fr/~jcourant/
Tel (+33) (0)1 69 15 64 85
GPG public key: 7C25 D439 9F60 BC68 A131  6267 98B9 98F6 7107 2457
