coq-club - Re: [Coq-Club]Coq and proving asm security properties
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Coq and proving asm security properties
  • Date: Sun, 19 Feb 2006 09:00:05 -0800
Ron wrote:
I am new to this list and interested in using a theorem prover to
semi-automatically prove that a certain executable containing binary
code(thus a dissassembly needs to be generated first) on e.g. Linux
contains no possibility for e.g. a buffer-overflow.
Are you familiar with the large existing body of work on Foundational Proof-Carrying Code? In this area, we prove theorems about machine code programs using no axioms but those of the machine architecture we run on. The most well-studied and -implemented theorems here are memory safety theorems, which I think subsume buffer-overflow checking, given the right definitions.
I'm aware of these FPCC projects that already use Coq:
- Those in the FLINT group at Yale: http://flint.cs.yale.edu/flint/publications/
- My co-authors' and my work on building scalable FPCC systems using proof-generating or proved-sound program verifiers: see the 1st and 3rd entries on http://www.cs.berkeley.edu/~adamc/papers/
There is also work in the area using Twelf in place of Coq:
- The original FPCC project at Princeton: http://www.cs.princeton.edu/sip/projects/pcc/
- The ConCert project at CMU: see the 1st entry in each of the 1st two categories of http://www.cs.cmu.edu/~crary/papers/
Coq seems to be a
well developed theorem prover, however, I read in Chapter 1 of Coq'Art
that Coq can't prove theorems about all computable functions(in
particular those that not terminate). So, it seems I can't use Coq for
my purposes, since I need to prove things over programs that are
possibly interactive, and hence don't need to terminate. Could anyone
provide some pointers, in case, it is possible to still use Coq?
I think you have confused the "meta language," or language of Coq itself (which is a programming language in its own right); with potential "object languages," or programming languages that you prove theorems about. There is no limitation against formalizing an object language that supports non-termination, and in fact all of the FPCC work I mentioned is in such a setting.
More in general, it seems everyone ignores I/O (I have only seen the
proof of the correctness of simple functions like max, sum, average,
etc in some high-level language in the papers I skimmed). Is there
some "trick" which makes I/O a non-issue? (I have seen dependent types
approaches, but those seem to be still at the theoretical level).
If you are only interested in buffer overflows, then you shouldn't need to model these exactly. In any case, the first link I gave above probably has the most relevant work on proving general correctness properties of machine code.
