coq-club - Re: [Coq-Club]Coq and proving asm security properties
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Coq and proving asm security properties
  • Date: Sun, 19 Feb 2006 15:10:50 -0800
Ron wrote:
Ok, that's very interesting. Do I understand correctly that you try to
load a binary and then load that up in Coq somehow, with the theorem
you want to prove about that program. And then a user could start
proving something about this? I.e. this is different from all the "oh,
we have this dependently typed language with programmers supplying all
the proofs"-approach :)
That's right. Coq is really just such a dependently typed language, with the extra facilities for interactive programming/proving.
If you don't have this cool typed assembly language, but only a binary
with x86, then that doesn't work, but if I understand correctly your
"library" does not assume a typed assembly, right?
The types in typed assembly language are just proof hints. TAL-based approaches are quite compatible with producing standard x86 binaries.
There is no idea of assembly-level types in the library I linked.
P.S. Did you or anybody else use the book Coq'Art to become
experienced with Coq? Can you recommend it? Amazon does not have
reviews.
I found it to be a very worthwhile book to read.
