coq-club - Re: [Coq-Club]Coq and proving asm security properties
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Coq and proving asm security properties
  • Date: Sun, 19 Feb 2006 23:58:13 +0100
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=WUOlpNGcMBgW03nwn1rKzdHGRl0q5uruwNAIhUPDn/4cqO2oPOQspqJHXxv7BCVqkNHde3Uq42Pg3g35ZfyZlJuNzZHpgxvqqQGrim4FW9YhV9NSZpoyzuyudfTueb8Co1Cwq6fkEPz/AFQgV8D5lP/SZIC3qnoytRN9vlSs8YE=
2006/2/19, Adam Chlipala
<adamc AT cs.berkeley.edu>:
> Ron wrote:
> >Now, it would be very interesting if someone would have formalized all
> >x86 instructions or similar. Did anyone do this?
> I've formalized in Coq the parts of x86 that I've needed so far for the
> tasks I've attempted.  There is the beginning of a re-usable library for
> parsing machine code (with OCaml) and proving things about the resulting
> ASTs (with Coq) here:
>     http://cvs.sourceforge.net/viewcvs.py/proofos/asm/
Ok, that's very interesting. Do I understand correctly that you try to
load a binary and then load that up in Coq somehow, with the theorem
you want to prove about that program. And then a user could start
proving something about this? I.e. this is different from all the "oh,
we have this dependently typed language with programmers supplying all
the proofs"-approach :)
> I know that some other people have also created formalizations, but none
> are really packaged for wide use.  I asked your exact question on this
> list before beginning the above library and received no positive answers.
Great initiative :)
> >Or if not, what is
> >the most complex program of which non-trivial statements have been
> >proved?
> If you count memory safety as non-trivial (and the proofs are quite
> non-trivial!), then we can prove facts about arbitrarily complicated
> programs; anything outputted by a certifying ML compiler, for instance,
> in a format like typed assembly language.  If that's not non-trivial
> enough for you, then probably the Certified Assembly Programming work at
> Yale has dealt with the most interesting properties that I've seen.
If you don't have this cool typed assembly language, but only a binary
with x86, then that doesn't work, but if I understand correctly your
"library" does not assume a typed assembly, right?
> >And what software is used most is this context? Coq? With what
> >libraries?
> Anecdotally, I've heard of the most projects in this area that use Coq.
Ok, then I am on the right track.
P.S. Did you or anybody else use the book Coq'Art to become
experienced with Coq? Can you recommend it? Amazon does not have
reviews.
