- To: Ron <iampure AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Coq and proving asm security properties
- Date: Sun, 19 Feb 2006 21:24:54 -0500
On Feb 19, 2006, at 5:58 PM, Ron wrote:
2006/2/19, Adam Chlipala
<adamc AT cs.berkeley.edu>:
Ron wrote:Ok, that's very interesting. Do I understand correctly that you try to
Now, it would be very interesting if someone would have formalized allI've formalized in Coq the parts of x86 that I've needed so far for the
x86 instructions or similar. Did anyone do this?
tasks I've attempted. There is the beginning of a re-usable library for
parsing machine code (with OCaml) and proving things about the resulting
ASTs (with Coq) here:
http://cvs.sourceforge.net/viewcvs.py/proofos/asm/
load a binary and then load that up in Coq somehow, with the theorem
you want to prove about that program. And then a user could start
proving something about this? I.e. this is different from all the "oh,
we have this dependently typed language with programmers supplying all
the proofs"-approach :)
I know that some other people have also created formalizations, but noneGreat initiative :)
are really packaged for wide use. I asked your exact question on this
list before beginning the above library and received no positive answers.
If you don't have this cool typed assembly language, but only a binary
Or if not, what isIf you count memory safety as non-trivial (and the proofs are quite
the most complex program of which non-trivial statements have been
proved?
non-trivial!), then we can prove facts about arbitrarily complicated
programs; anything outputted by a certifying ML compiler, for instance,
in a format like typed assembly language. If that's not non-trivial
enough for you, then probably the Certified Assembly Programming work at
Yale has dealt with the most interesting properties that I've seen.
with x86, then that doesn't work, but if I understand correctly your
"library" does not assume a typed assembly, right?
Ok, then I am on the right track.And what software is used most is this context? Coq? With whatAnecdotally, I've heard of the most projects in this area that use Coq.
libraries?
P.S. Did you or anybody else use the book Coq'Art to become
experienced with Coq? Can you recommend it? Amazon does not have
reviews.
I have a copy of Coq'Art, and my opinion is that it is quite good. I refer to it with some frequency. I went into reading it after having worked with Coq for a couple of weeks; I think it was easier reading for that. I think otherwise I would have done more re-reading and scratching my head. That said, there are some of the more esoteric areas that Coq'Art doesn't cover. For example, there is an important restriction on inductive definitions called some thing like the "positivity requirement" which I could not find in Coq'Art; I had to dig around in the documentation and finally read a journal paper before I found a satisfactory explanation of what this restriction is and why it exists.
Short version: it's good. Get it if you plan to do any serious work with Coq.
Rob Dockins
Speak softly and drive a Sherman tank.
Laugh hard; it's a long way to the bank.
-- TMBG
- [Coq-Club]Coq and proving asm security properties, Ron
- Re: [Coq-Club]Coq and proving asm security properties,
Lionel Elie Mamane
Ron
Adam Chlipala
Ron
- Re: [Coq-Club]Coq and proving asm security properties, Adam Chlipala
- Re: [Coq-Club]Coq and proving asm security properties, Robert Dockins
Pierre Casteran
- Re: [Coq-Club]Coq and proving asm security properties, Conor McBride
Pierre Casteran
Ron
- Re: [Coq-Club]Coq and proving asm security properties, Lionel Elie Mamane
Adam Chlipala
Ron
Lionel Elie Mamane
