- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Coq and proving asm security properties
- Date: Sun, 19 Feb 2006 14:34:24 -0800
Ron wrote:
Now, it would be very interesting if someone would have formalized allI've formalized in Coq the parts of x86 that I've needed so far for the tasks I've attempted. There is the beginning of a re-usable library for parsing machine code (with OCaml) and proving things about the resulting ASTs (with Coq) here:
x86 instructions or similar. Did anyone do this?
http://cvs.sourceforge.net/viewcvs.py/proofos/asm/
I know that some other people have also created formalizations, but none are really packaged for wide use. I asked your exact question on this list before beginning the above library and received no positive answers.
Or if not, what isIf you count memory safety as non-trivial (and the proofs are quite non-trivial!), then we can prove facts about arbitrarily complicated programs; anything outputted by a certifying ML compiler, for instance, in a format like typed assembly language. If that's not non-trivial enough for you, then probably the Certified Assembly Programming work at Yale has dealt with the most interesting properties that I've seen.
the most complex program of which non-trivial statements have been
proved?
And what software is used most is this context? Coq? With whatAnecdotally, I've heard of the most projects in this area that use Coq.
libraries?
- [Coq-Club]Coq and proving asm security properties, Ron
- Re: [Coq-Club]Coq and proving asm security properties,
Lionel Elie Mamane
Ron
- Re: [Coq-Club]Coq and proving asm security properties, Adam Chlipala
Ron
Robert Dockins
Pierre Casteran
- Re: [Coq-Club]Coq and proving asm security properties, Conor McBride
- Re: [Coq-Club]Coq and proving asm security properties, Robert Dockins
Pierre Casteran
Ron
- Re: [Coq-Club]Coq and proving asm security properties, Lionel Elie Mamane
Ron
Lionel Elie Mamane
