- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]ring_simplify
- Date: Wed, 14 Mar 2007 11:26:37 +0100 (CET)
Hello,
I have just begun using coq V8.1 and the new ring tactics. I am currently fighting with the normal form given by the tactic ring_simplify. More precisely, I have discovered that it now uses the notation "^" when the same term is multiplied by itself. That is nicer to look at, but very difficult to use afterwards. When unfolded, a^2 becomes a*(a*1), therefore rewriting on a*a is impossible :-(
Simplified example:
Require Import Reals.
Variable a:R.
Hypothesis H: (a*a=1)%R.
Theorem toto: forall (b:R), (a*a*a-b+b=a)%R.
intros.
ring_simplify.
unfold pow.
(* here rewrite H fails *)
This is not impossible to solve (with nicely chosen replace), but it is a real pain for complex a and b.
Would it be possible that the chosen pow (the one I get when I use ring_simplify), when unfolded, would give the expected answer ?
In fact, I would like a^2 to be a*a...
Regards,
Sylvie Boldo
Sylvie Boldo, projet ProVal, INRIA Futurs
- [Coq-Club]ring_simplify, Sylvie . Boldo
- Re: [Coq-Club]ring_simplify,
Thery Laurent
Sylvie . Boldo
- Re: [Coq-Club]ring_simplify, Benjamin Gregoire
Thery Laurent
Sylvie . Boldo
- Re: [Coq-Club]ring_simplify, Bruno Barras
Sylvie . Boldo
Sylvie . Boldo
Thery Laurent
