coq-club - Re: [Coq-Club]ring_simplify
chronological Thread
  • From: Benjamin Gregoire <Benjamin.Gregoire AT sophia.inria.fr>
  • To: Sylvie.Boldo AT inria.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]ring_simplify
  • Date: Wed, 14 Mar 2007 13:39:37 +0100
 wrote:
  Hello Sylvie,
This is not really an answer to your questions but it will solve your problem :
The ring(_simplify) tactics are able to compute a normal form modulo rewriting, the rewriting equality should be of the
following form : n*M = P, where n is a number, M a monomial and P a polynomial.
       So you can prove your goal as follow:
            intros; ring_simplify [H].
        >> a = a
            trivial.
        >> Proof completed.
       Or simply :
intros; ring [H]. >> Proof completed.
You can give more than one hypothesis : ring [H1, H2, H3].
  Hope this help.
      Benjamin
Hello,
I have just begun using coq V8.1 and the new ring tactics. I am currently fighting with the normal form given by the tactic ring_simplify. More precisely, I have discovered that it now uses the notation "^" when the same term is multiplied by itself. That is nicer to look at, but very difficult to use afterwards. When unfolded, a^2 becomes a*(a*1), therefore rewriting on a*a is impossible :-(
Simplified example:
Require Import Reals.
Variable a:R.
Hypothesis H: (a*a=1)%R.
Theorem toto: forall (b:R), (a*a*a-b+b=a)%R.
intros.
ring_simplify.
unfold pow.
 (* here rewrite H fails *)
This is not impossible to solve (with nicely chosen replace), but it is a real pain for complex a and b.
Would it be possible that the chosen pow (the one I get when I use ring_simplify), when unfolded, would give the expected answer ?
In fact, I would like a^2 to be a*a...
Regards,
Sylvie Boldo
