coq-club - Re: [Coq-Club]ring_simplify
chronological Thread
  • To: Thery Laurent <thery AT ns.di.univaq.it>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]ring_simplify
  • Date: Wed, 14 Mar 2007 16:47:13 +0100 (CET)
Hi,
Thanks for the replies ! I missed the reference to ring[H] in the manual.
Unfortunately, it solves the simplified example, but not the real one :°-(
Less simplified example:
Require Import Reals.
Variable f:R->R.
Hypothesis H: forall (a b:R), (f a*f b=f (a*b))%R.
Theorem toto: forall (a b c:R), (f(a)*(f(a)-b)+b*f(a)=f(a*a))%R.
I would have to use ring [H a a] but it is highly unpractical.
In fact, I was using "repeat rewrite <- H" so in practise, I would need to use [H a b, H b -a, H b a, H c a....] with "big" a,b & c...
Yes it is a small incompatibility with the previous ring_simplify
but we thought that the benefit of having more readable outputs was
worth it. Anyway having or not a power function is a flag in the
primitive  ring tactic. It is just activated when applied to R.
If you happen to have too much problem, we could turn in down.
Well, it IS more readable, no doubt about it. I see 2 possible answers that would solve my problem:
 * having a flag to turn it down if wanted
* using a different pow such that a^2=a*a, knowing that this pow will be used in a^b with b >=2 (this is the real case as ring_simplify will use pow only when it is at least a square.
Having full associative commutative rewriting in Coq would
of course be nicer, I hope it will come with coq8.2 :-)
I fully agree :-)
Sylvie Boldo
Sylvie Boldo, projet ProVal, INRIA Futurs
