- To: Sylvie.Boldo AT inria.fr
- Cc: Thery Laurent <thery AT ns.di.univaq.it>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]ring_simplify
- Date: Thu, 15 Mar 2007 15:20:12 +0100
wrote:
Hello,
Hello,
Many thanks Benjamin for the solution modifying ring !!
It works great (and does not get out of sections). I never thought I would ever modify ring...
You have no idea of all the things you can modify in the new ring! In fact the only thing that is hardwired is the definition of the ring structure (and possibly one or two things from InitialRing.v). Then, all that is coded in ML is a tactic called ring_lookup that, given a list of terms, returns the appropriate ring structure and auxiliary tactics (constant, pre and post). All that is defined in Ring_polynom and Ring_tac could be duplicated and modified as you need, and define a new tactic ring2 that take advantage of all (past and future) Add Ring declarations.
Well, OK, for the moment, you have to dig in the guts of the tactic, and the code could probably be simpler, so you have to invest some time to achieve significant changes.
Regarding the ring_simplify tactic, I should warn you that it is a quite unstable tactic, and the spec of the normal forms changes quite often as Benjamin, Laurent (or I) code new features. ring is *much* more robust, and when possible you should really consider replacing ring_simplify by (replace <expr1> with <expr2> by ring). When expressions are big, using "match goal with ..." to extract large subterms of the goal can help.
Bruno.
- [Coq-Club]ring_simplify, Sylvie . Boldo
- Re: [Coq-Club]ring_simplify,
Thery Laurent
Sylvie . Boldo
- Re: [Coq-Club]ring_simplify, Benjamin Gregoire
Thery Laurent
Sylvie . Boldo
- Re: [Coq-Club]ring_simplify, Bruno Barras
Sylvie . Boldo
Sylvie . Boldo
Thery Laurent
