coq-club - Re: [Coq-Club]ring_simplify
chronological Thread
  • To: Sylvie.Boldo AT inria.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]ring_simplify
  • Date: Wed, 14 Mar 2007 13:37:50 +0100 (CET)
Hi
I have just begun using coq V8.1 and the new ring tactics. I am currently fighting with the normal form given by the tactic ring_simplify. More precisely, I have discovered that it now uses the notation "^" when the same term is multiplied by itself. That is nicer to look at, but very difficult to use afterwards. When unfolded, a^2 becomes a*(a*1), therefore rewriting on a*a is impossible :-(
Yes it is a small incompatibility with the previous ring_simplify
but we thought that the benefit of having more readable outputs was
worth it. Anyway having or not a power function is a flag in the
primitive  ring tactic. It is just activated when applied to R.
If you happen to have too much problem, we could turn in down.
Theorem toto: forall (b:R), (a*a*a-b+b=a)%R.
intros.
ring_simplify.
unfold pow.
(* here rewrite H fails *)
In this particular example you can make use of the capability of
ring to do some restricted form of rewriting modulo assoc/comm with
ring_simplify [H]
Having full associative commutative rewriting in Coq would
of course be nicer, I hope it will come with coq8.2 :-)
Laurent
