coq-club - [Coq-Club] Inductive definitions that go through lists
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Inductive definitions that go through lists
  • Date: Tue, 20 Nov 2007 22:20:03 -0500
This week, I wanted to show my programming languages class how to extend the simply typed lambda-calculus with records. So I wrote the obvious thing:
   Inductive ty : Set :=
     | ty_base     : nat -> ty
     | ty_arrow    : ty -> ty -> ty
     | ty_rcd      : (alist ty) -> ty.
This seemed happy for a while, until I discovered that the induction principle Coq had generated
   ty_ind
     : forall P : ty -> Prop,
       (forall n : nat, P (ty_base n)) ->
(forall t : ty, P t -> forall t0 : ty, P t0 -> P (ty_arrow t t0)) ->
       (forall a : alist ty, P (ty_rcd a)) -> forall t : ty, P t
was completely useless! (The last case gives no IH for reasoning about records.)
I asked around a little at Penn and was told that this was a common issue and the usual way around it was to "lift" the nil and cons constructors of lists into my term syntax, like this:
    | ty_rcd_nil  : ty
    | ty_rcd_cons : nat -> ty -> ty -> ty.
This made me a little less happy because it slightly changes the language I'm defining, but I pushed ahead and succeeded in proving all the things I wanted to about the system.
Next, I'd like to show the class the "dual" extension: variants (i.e., disjoint sums with any number of labeled summands). But this time I'm even less happy. I'd like to write
  Inductive tm : Set :=
    | tm_var : nat -> tm
    | tm_app : tm -> tm -> tm
    | tm_abs : nat -> ty -> tm -> tm
    | tm_inj : nat -> tm -> tm
    | tm_case : tm -> list (nat * tm) -> tm.
where the last constructor represents an n-ary case construct whose concrete syntax might look like this:
     case t0 of <l1=x1> => t1
              | <ln=xn> => tn
This won't work for the same reason as before. And, while I can roughly see how to generalize the "case" constructor into a "nil" and a "cons" part as I did for records, this is really getting a bit awkward.
Is there a more direct way to do such things?
Thanks!
    - Benjamin
