- From: Francesco Zappa Nardelli <francesco.zappa_nardelli AT inria.fr>
- To: coq-club AT pauillac.inria.fr
- Cc: Francesco Zappa Nardelli <francesco.zappa_nardelli AT inria.fr>, Peter Sewell <peter.sewell AT cl.cam.ac.uk>
- Subject: Re: [Coq-Club] Inductive definitions that go through lists
- Date: Wed, 21 Nov 2007 18:17:56 +0100
Dear all
I meant solutions written in Coq, of course. Could it be the case
that other provers are less challenged than Coq by mutual inductive
definitions and by T / list T inductive definitions?
As a test case for the Ott tool, we defined several fragments of languages defined in TAPL (using a "fully concrete" representation for binders) and we proved type preservation in Isabelle/Hol, Hol, and Coq.
The result of our experience is that proofs of fragments involving list types (e.g.. records) turned out to be much simpler in Hol (proofs done by Scott Owens) and Isabelle/Hol (proofs done by Thomas Ridge) than in Coq. (However this is a personal experience, and the result might just be related to the experience of the man driving the theorem prover).
The Hol and Isabelle/Hol scripts are available from http:// moscova.inria.fr/~zappa/software/ott (example TAPL-roughly-full- simple).
In Coq developments related to programming language theory, extending "Scheme" would save a lot of redefinitions of list types like in the example above.
Very suboptimal, but, given the syntax of your language definition, the Ott tool can generate the most general induction principle, which you can then copy/paste into your Coq development.
Regards
-francesco
- [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
- Re: [Coq-Club] Inductive definitions that go through lists, Robert Dockins
Benjamin Werner
Thorsten Altenkirch
Stéphane Lescuyer
- Re: [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
Stéphane Lescuyer
Xavier Leroy
Xavier Leroy
- Re: [Coq-Club] Inductive definitions that go through lists, Francesco Zappa Nardelli
- Re: [Coq-Club] Inductive definitions that go through lists, Stefan Berghofer
Thorsten Altenkirch
Benjamin Werner
- Re: [Coq-Club] Inductive definitions that go through lists, frederic . blanqui
Benjamin Werner
Xavier Leroy
Thorsten Altenkirch
