coq-club - Re: [Coq-Club] Inductive definitions that go through lists
chronological Thread
  • To: St�phane Lescuyer <lescuyer AT lri.fr>
  • Cc: "Thorsten Altenkirch" <txa AT cs.nott.ac.uk>, coq-club AT pauillac.inria.fr, "Peter Morris" <pwm AT cs.nott.ac.uk>, "Benjamin Werner" <Benjamin.Werner AT inria.fr>
  • Subject: Re: [Coq-Club] Inductive definitions that go through lists
  • Date: Wed, 21 Nov 2007 11:02:13 -0500
Thank you, everybody!!!  This is all extremely useful...
    - Benjamin
On Nov 21, 2007, at 8:14 AM, Stéphane Lescuyer wrote:
Hi Benjamin,
Although Benjamin W's solution will do the trick in most situations,
you may find yourself a situation where the 'lifted predicate' for lists
associated with the predicate P you want to prove is not of the above
form, namely you cannot prove (P (ty_rcd tl)) by just knowing (P t) for
every t in tl, but you need a more global property of the list tl, which
means you would design an ad hoc predicate over lists corresponding to P.
In such cases, you might need the following (and I believe, more general)
induction principle :
 Inductive ty : Set :=
     | ty_base     : nat -> ty
     | ty_arrow    : ty -> ty -> ty
     | ty_rcd      : (list ty) -> ty.
Section ty_ind.
  (** P is the predicate you wish to prove, liftedP is P lifted over
lists in "some way" *)
  Variables (P : ty -> Type) (liftedP : list ty -> Type).
  Hypotheses
   (** Traditional induction hypotheses *)
   (Hbase : forall n, P (ty_base n))
   (Harrow : forall ty1 ty2, P ty1 -> P ty2 -> P (ty_arrow ty1 ty2))
   (** Special hypotheses for the ty_rcd case *)
   (H_rcd   : forall lt, liftedP lt -> P (ty_rcd lt))
   (H_rcd0 : liftedP nil)
   (H_rcd1 : forall t lt, P t -> (liftedP lt) -> liftedP (t::lt)).
  (** Then you can define the induction principle *)
  Fixpoint ty_ind_alt (t : ty) : P t :=
    match t as x return P x with
    | ty_base n => Hbase n
    | ty_arrow t1 t2 => Harrow t1 t2 (ty_ind_alt t1) (ty_ind_alt t2)
    | ty_rcd lt =>
      H_rcd lt (((fix l_ind (lty : list ty) : liftedP lty :=
                     match lty as x return liftedP x with
                     | nil => H_rcd0
| cons t lty' => H_rcd1 t lty' (ty_ind_alt t) (l_ind lty')
                     end)) lt)
   end.
End ty_ind.
You can easily design the same kind of induction principles for a
predicate over two types t1 and t2, which comes in handy at times.
Hope this helps,
Stéphane Lescuyer
http://www.lri.fr/~lescuyer/
On Nov 21, 2007 12:50 PM, Thorsten Altenkirch <txa AT cs.nott.ac.uk> wrote:
Hi,
some comments on the Benjamins' emails:
Indeed, every strictly positive operator on types F : Type -> Type
gives rise to a modality:
        P : A -> Type
        [] F : F A -> Type
moreover, we have a dependent version of map
        f : forall a:A, P a
        dmap f : forall x:F A,[] P x
Using this, one can formulate a generic eliminator for the inductive
type mu F:Type with the constructor
in : F(mu F) -> mu F:
        P : mu F -> Type
         m :  forall x:F(mu F), [] P x -> P (in x)
        elim P m : forall x:mu F,  P x
and the computation rule
        elim P m (in x) = dmap (elim P m) x
Benjamin P's type is isomorphic to the inductive type generated by
        F X = nat + X * X + list X
which is strictly positive because X appears strictly positive in
list X. This is the theory, how difficult (and how useful) it would
be to implement it in Coq, I don't know.
Peter Morris investigated the [] modality (and its dual <>) in his
recent PhD thesis on generic programming with dependent types (http://
www.cs.nott.ac.uk/~pwm/thesis.pdf).
Actually, in an extensional theory every functor gives rise to the []-
modality, but only strictly positive ones (or containers) give rise
to the dual <>, it seems. In any case, from a foundational point of
view one may not want to accept non-strictly positive inductive types
(like mu X.(X->Bool)->Bool) anyway.
Cheers,
Thorsten
On 21 Nov 2007, at 10:32, Benjamin Werner wrote:
     Hello Benjamin,
The Coq implementation does not provide a good induction principle,
but the type theory does not forbid it.
You first have to state what your induction principle has to look
like, and thus what the induction
hypothesis for the   (alist ty)  looks like.
Here is one possibility. I just replaced alist by list for
simplification:
Fixpoint liftp (P:ty->Prop)(l:list ty) {struct l} : Prop := match l
with
| cons t l => P t /\ liftp P l
| _ => True
end.
Lemma ty_myind : forall P : ty -> Prop,
       (forall n : nat, P (ty_base n)) ->
       (forall t : ty, P t -> forall t0 : ty, P t0 -> P (ty_arrow t
t0)) ->
       (forall a : list ty,liftp P a ->  P (ty_rcd a)) ->
         (forall t : ty, P t).
Proof.
fix 5.
intros P pb pa pl [n|t u|l].
apply pb.
apply pa; apply ty_myind; auto.
apply pl.
elim l.
 simpl; trivial.
clear l; intros t l hl; split.
 apply ty_myind; trivial.
assumption.
Qed.
Note that:
* When using the (not very documented) fix tactic, you have to be
careful
not using your induction hypothesis too early in the proof. If not,
you get
an unpleasant surprise when you do Qed.
(basically, fix gives you a too strong IH, it is your
responsability to apply
it only to arguments which are structurally smaller).
* In the example above, you then have to prove that under the same
hypotheses
you have (liftp P l) for any  l: list ty
but this should be easy by (regular) induction over l and using
ty_myind.
* The definitions of the type theory which make this correct are
described in the ref man.
The fix tactic is in the tutorial on recursive types (Gimenez and
Casteran).
Maybye there are smoother versions of the above. Also, my
understanding is
that if this work is not done generically by Coq, it is a.o.
because it is not so
trivial to state the good induction principle.
Hope this helps,
Benjamin
Le 21 nov. 07  04:20, Benjamin Pierce a crit :
This week, I wanted to show my programming languages class how to
extend the simply typed lambda-calculus with records.  So I wrote
the obvious thing:
     | ty_rcd      : (alist ty) -> ty.
This seemed happy for a while, until I discovered that the
induction principle Coq had generated
   ty_ind
t t0)) ->
       (forall a : alist ty, P (ty_rcd a)) -> forall t : ty, P t
was completely useless!  (The last case gives no IH for reasoning
about records.)
I asked around a little at Penn and was told that this was a
common issue and the usual way around it was to "lift" the nil and
cons constructors of lists into my term syntax, like this:
    | ty_rcd_nil  : ty
    | ty_rcd_cons : nat -> ty -> ty -> ty.
This made me a little less happy because it slightly changes the
language I'm defining, but I pushed ahead and succeeded in proving
all the things I wanted to about the system.
Next, I'd like to show the class the "dual" extension: variants
(i.e., disjoint sums with any number of labeled summands).  But
this time I'm even less happy.  I'd like to write
  Inductive tm : Set :=
    | tm_var : nat -> tm
    | tm_app : tm -> tm -> tm
    | tm_abs : nat -> ty -> tm -> tm
    | tm_inj : nat -> tm -> tm
    | tm_case : tm -> list (nat * tm) -> tm.
where the last constructor represents an n-ary case construct
whose concrete syntax might look like this:
     case t0 of <l1=x1> => t1
              | <ln=xn> => tn
This won't work for the same reason as before.  And, while I can
roughly see how to generalize the "case" constructor into a "nil"
and a "cons" part as I did for records, this is really getting a
bit awkward.
Is there a more direct way to do such things?
Thanks!
    - Benjamin
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
