- To: "Thorsten Altenkirch" <txa AT cs.nott.ac.uk>
- Cc: coq-club AT pauillac.inria.fr, "Benjamin Pierce" <bcpierce AT cis.upenn.edu>, "Peter Morris" <pwm AT cs.nott.ac.uk>, "Benjamin Werner" <Benjamin.Werner AT inria.fr>
- Subject: Re: [Coq-Club] Inductive definitions that go through lists
- Date: Wed, 21 Nov 2007 14:14:13 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=hf4/mw9jWUZmX3Zet0yVk3xFlD9o1x74R2uX0tZnvpUJjEOgkR8uGAT3i2IYBfdDNocFPycfVNUeXSdZCNiCEUVwjMRCjY/eh8SRzFVmwEf+Mu2TJBA8k9Y2NAmmTzlPKbU+izmTgWA4EW2gq6abJT5c2OCZj8F+O58gpefiJ24=
Hi Benjamin,
Although Benjamin W's solution will do the trick in most situations,
you may find yourself a situation where the 'lifted predicate' for lists
associated with the predicate P you want to prove is not of the above
form, namely you cannot prove (P (ty_rcd tl)) by just knowing (P t) for
every t in tl, but you need a more global property of the list tl, which
means you would design an ad hoc predicate over lists corresponding to P.
In such cases, you might need the following (and I believe, more general)
induction principle :
Inductive ty : Set :=
| ty_base : nat -> ty
| ty_arrow : ty -> ty -> ty
| ty_rcd : (list ty) -> ty.
Section ty_ind.
(** P is the predicate you wish to prove, liftedP is P lifted over
lists in "some way" *)
Variables (P : ty -> Type) (liftedP : list ty -> Type).
Hypotheses
(** Traditional induction hypotheses *)
(Hbase : forall n, P (ty_base n))
(Harrow : forall ty1 ty2, P ty1 -> P ty2 -> P (ty_arrow ty1 ty2))
(** Special hypotheses for the ty_rcd case *)
(H_rcd : forall lt, liftedP lt -> P (ty_rcd lt))
(H_rcd0 : liftedP nil)
(H_rcd1 : forall t lt, P t -> (liftedP lt) -> liftedP (t::lt)).
(** Then you can define the induction principle *)
Fixpoint ty_ind_alt (t : ty) : P t :=
match t as x return P x with
| ty_base n => Hbase n
| ty_arrow t1 t2 => Harrow t1 t2 (ty_ind_alt t1) (ty_ind_alt t2)
| ty_rcd lt =>
H_rcd lt (((fix l_ind (lty : list ty) : liftedP lty :=
match lty as x return liftedP x with
| nil => H_rcd0
| cons t lty' => H_rcd1 t lty' (ty_ind_alt t) (l_ind
lty')
end)) lt)
end.
End ty_ind.
You can easily design the same kind of induction principles for a
predicate over two types t1 and t2, which comes in handy at times.
Hope this helps,
Stéphane Lescuyer
http://www.lri.fr/~lescuyer/
On Nov 21, 2007 12:50 PM, Thorsten Altenkirch
wrote:
> Hi,
> some comments on the Benjamins' emails:
> Indeed, every strictly positive operator on types F : Type -> Type
> gives rise to a modality:
> P : A -> Type
> [] F : F A -> Type
> moreover, we have a dependent version of map
> f : forall a:A, P a
> dmap f : forall x:F A,[] P x
> Using this, one can formulate a generic eliminator for the inductive
> type mu F:Type with the constructor
> in : F(mu F) -> mu F:
> P : mu F -> Type
> m : forall x:F(mu F), [] P x -> P (in x)
> elim P m : forall x:mu F, P x
> and the computation rule
> elim P m (in x) = dmap (elim P m) x
> Benjamin P's type is isomorphic to the inductive type generated by
> F X = nat + X * X + list X
> which is strictly positive because X appears strictly positive in
> list X. This is the theory, how difficult (and how useful) it would
> be to implement it in Coq, I don't know.
> Peter Morris investigated the [] modality (and its dual <>) in his
> recent PhD thesis on generic programming with dependent types (http://
> www.cs.nott.ac.uk/~pwm/thesis.pdf).
> Actually, in an extensional theory every functor gives rise to the []-
> modality, but only strictly positive ones (or containers) give rise
> to the dual <>, it seems. In any case, from a foundational point of
> view one may not want to accept non-strictly positive inductive types
> (like mu X.(X->Bool)->Bool) anyway.
> Cheers,
> Thorsten
> On 21 Nov 2007, at 10:32, Benjamin Werner wrote:
> > Hello Benjamin,
> > The Coq implementation does not provide a good induction principle,
> > but the type theory does not forbid it.
> > You first have to state what your induction principle has to look
> > like, and thus what the induction
> > hypothesis for the (alist ty) looks like.
> > Here is one possibility. I just replaced alist by list for
> > simplification:
> > | ty_base : nat -> ty
> > Fixpoint liftp (P:ty->Prop)(l:list ty) {struct l} : Prop := match l
> > with
> > | cons t l => P t /\ liftp P l
> > | _ => True
> > end.
> > Lemma ty_myind : forall P : ty -> Prop,
> > (forall n : nat, P (ty_base n)) ->
> > (forall t : ty, P t -> forall t0 : ty, P t0 -> P (ty_arrow t
> > t0)) ->
> > (forall a : list ty,liftp P a -> P (ty_rcd a)) ->
> > (forall t : ty, P t).
> > Proof.
> > fix 5.
> > intros P pb pa pl [n|t u|l].
> > apply pb.
> > apply pa; apply ty_myind; auto.
> > apply pl.
> > elim l.
> > simpl; trivial.
> > clear l; intros t l hl; split.
> > apply ty_myind; trivial.
> > assumption.
> > Qed.
> > Note that:
> > * When using the (not very documented) fix tactic, you have to be
> > careful
> > not using your induction hypothesis too early in the proof. If not,
> > you get
> > an unpleasant surprise when you do Qed.
> > (basically, fix gives you a too strong IH, it is your
> > responsability to apply
> > it only to arguments which are structurally smaller).
> > * In the example above, you then have to prove that under the same
> > hypotheses
> > you have (liftp P l) for any l: list ty
> > but this should be easy by (regular) induction over l and using
> > ty_myind.
> > * The definitions of the type theory which make this correct are
> > described in the ref man.
> > The fix tactic is in the tutorial on recursive types (Gimenez and
> > Casteran).
> > Maybye there are smoother versions of the above. Also, my
> > understanding is
> > that if this work is not done generically by Coq, it is a.o.
> > because it is not so
> > trivial to state the good induction principle.
> > Hope this helps,
> > Benjamin
> > Le 21 nov. 07 04:20, Benjamin Pierce a crit :
> >> This week, I wanted to show my programming languages class how to
> >> extend the simply typed lambda-calculus with records. So I wrote
> >> the obvious thing:
> >> | ty_base : nat -> ty
> >> | ty_rcd : (alist ty) -> ty.
> >> This seemed happy for a while, until I discovered that the
> >> induction principle Coq had generated
> >> ty_ind
> >> t t0)) ->
> >> (forall a : alist ty, P (ty_rcd a)) -> forall t : ty, P t
> >> was completely useless! (The last case gives no IH for reasoning
> >> about records.)
> >> I asked around a little at Penn and was told that this was a
> >> common issue and the usual way around it was to "lift" the nil and
> >> cons constructors of lists into my term syntax, like this:
> >> | ty_base : nat -> ty
> >> | ty_rcd_nil : ty
> >> | ty_rcd_cons : nat -> ty -> ty -> ty.
> >> This made me a little less happy because it slightly changes the
> >> language I'm defining, but I pushed ahead and succeeded in proving
> >> all the things I wanted to about the system.
> >> Next, I'd like to show the class the "dual" extension: variants
> >> (i.e., disjoint sums with any number of labeled summands). But
> >> this time I'm even less happy. I'd like to write
> >> Inductive tm : Set :=
> >> | tm_var : nat -> tm
> >> | tm_app : tm -> tm -> tm
> >> | tm_abs : nat -> ty -> tm -> tm
> >> | tm_inj : nat -> tm -> tm
> >> | tm_case : tm -> list (nat * tm) -> tm.
> >> where the last constructor represents an n-ary case construct
> >> whose concrete syntax might look like this:
> >> case t0 of <l1=x1> => t1
> >> | <ln=xn> => tn
> >> This won't work for the same reason as before. And, while I can
> >> roughly see how to generalize the "case" constructor into a "nil"
> >> and a "cons" part as I did for records, this is really getting a
> >> bit awkward.
> >> Is there a more direct way to do such things?
> >> Thanks!
> >> - Benjamin
> >> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> >> Archives: http://pauillac.inria.fr/pipermail/coq-club
> >> http://pauillac.inria.fr/bin/wilma/coq-club
> >> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
> This message has been checked for viruses but the contents of an attachment
> may still contain software viruses, which could damage your computer system:
> you are advised to perform your own checks. Email communications with the
> University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
- Re: [Coq-Club] Inductive definitions that go through lists, Robert Dockins
Benjamin Werner
Thorsten Altenkirch
- Re: [Coq-Club] Inductive definitions that go through lists, Stéphane Lescuyer
- Re: [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
Xavier Leroy
Xavier Leroy
- Re: [Coq-Club] Inductive definitions that go through lists, Francesco Zappa Nardelli
- Re: [Coq-Club] Inductive definitions that go through lists, Stefan Berghofer
Thorsten Altenkirch
Benjamin Werner
- Re: [Coq-Club] Inductive definitions that go through lists, frederic . blanqui
Benjamin Werner
Xavier Leroy
Thorsten Altenkirch
