coq-club - Re: [Coq-Club] Matching non-empty vectors
chronological Thread
  • To: Dimitri Hendriks <diem AT cs.vu.nl>
  • Cc: Michael Day <mikeday AT yeslogic.com>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Matching non-empty vectors
  • Date: Fri, 28 Mar 2008 11:00:41 +0100
I forgot the type parameter A in the definition of get_first,
it should be:
Definition get_first (A : Type) (n:nat) (v : vec A (S n)) : A :=
    match v in (vec _ m) return (m = S n -> A) with
    | Vnil => fun H => False_rect A (disc_O_S n H)
    | Vcons a _ _ => fun _ => a
    end (refl_equal (S n)).
On 28 Mar 2008, at 10:36, Dimitri Hendriks wrote:
for pattern matching over dependent types you
have to use an explicit elimination predicate
to predict the type of the righthand side.
see ch. 15 of the manual.
if you first define your function with tactics:
Definition get_first (A : Type) (n:nat) (v : vec A (S n)) : A.
intros A n v.
inversion v as [ | a m w H ].
exact a.
Defined.
and then inspect the built lambda-term:
Print get_first.
you can see what the predicate should look like:
  (vec m) -> (m = S n -> A)
and this may insprire you to write for instance:
Lemma disc_O_S : forall n, O <> S n.
intros n H.
discriminate H.
Qed.
Definition get_first (n:nat) (v : vec (S n)) : A :=
  match v in (vec m) return (m = S n -> A) with
dimitri
On 28 Mar 2008, at 09:07, Michael Day wrote:
Hi,
I have defined a simple vector type and a function to get the first element of non-empty vectors as follows:
Inductive vec (A:Type) : nat -> Type :=
    | Vnil : vec A 0
    | Vcons : forall (a:A) (n:nat), vec A n -> vec A (S n).
Definition get_first (A:Type) (n:nat) (v:vec A (S n)) (default:A) : A :=
    match v with
    | Vnil => default    (* I want to delete this line *)
    | Vcons a _ _ => a
    end.
Coq prevents me from calling get_first with an empty vector, so the Vnil case will never be matched and the default value will never be used. However, Coq does not permit me to omit this case:
Error: Non exhaustive pattern-matching: no clause found for pattern Vnil
This is incredibly frustrating. Why does Coq think that "Vnil" is an inhabitant of "vec (S n)"? After reading Conor McBride's papers on Epigram I expect the system to understand that 0 <> S n :)
The Vhead function in the Bvector module in the standard library uses the inversion tactic instead, but that seems to generate a very large and complicated definition for something that should be quite simple.
Best regards,
Michael
Print XML with Prince!
http://www.princexml.com
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
