- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Matching non-empty vectors
- Date: Fri, 28 Mar 2008 22:45:41 +1100
Hi Dimitri and James,
Thank you very much for your help! I'll have to spend some more time studying pattern matching. I also need to get over my aversion to using False_rect, which feels very discomfiting from a programming point of view, rather like:
if (0 == 1) { ... perform complicated calculations that can never actually happen but must still type check ... }
Returning "I" dulls the pain somewhat :)
Of course if you use this trick, then you still (might) need to do by hand the equational pre-processing of families P which Epigram would do for you in more complex examples such as Vec_tail, where you need to do the equational reasoning to push a Vec n to a Vec m ... having simplified Sm = Sn to m = n etc.
How usable is Epigram these days? I remember getting very excited about it back in 2005 I think it was, and looking forward to using it for development work. How the time goes.
It is true that a true 'dependent pattern matching' vernacular syntax would be very nice to have in Coq, ... so people have begun working on this. In the meantime, let the optional 'return' clause in match expressions be your friend...
Would that syntax actually be any different, or is it more a matter of getting Coq to do the rewriting by it self in the background, much as the Program mechanism purports to do?
Best regards,
Michael
Print XML with Prince!
http://www.princexml.com
- [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors,
Dimitri Hendriks
- Re: [Coq-Club] Matching non-empty vectors, Dimitri Hendriks
James McKinna
- Re: [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors, Matthieu Sozeau
Dimitri Hendriks
