- To: Michael Day <mikeday AT yeslogic.com>
- Cc: Dimitri Hendriks <diem AT cs.vu.nl>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Matching non-empty vectors
- Date: Fri, 28 Mar 2008 12:08:58 +0100
- Organization: Radboud Universiteit Nijmegen
Michael,
Dmitri is right to alert you to the use of an explicit 'return family' P in the match syntax
match <term> in <type> return P with...
But you can make slightly better use of this syntax to streamline Dmitri's idea (I learnt this trick from Hugo Herbelin in Tallinn at Christmas last year, but it may well be much older, going back to when V8.0 introduced 'return' clauses to match expressions): namely to choose a nice family P which:
--- is trivial in the 'bad' cases;
--- does 'what you want' in the good ones.
E.g. here you could try
P = match m with 0 => True | S _ => A
to obtain
Definition get_first (n:nat) (v : vec (S n)) : A :=
match v in (vec m) return (match m with 0 => True | S _ => A) with
| Vnil => I
| Vcons a _ _ => a
where I is the trivial proof of True which knocks off the bad Vnil branch. In this case you don't even need the equations and simplifications and reflexivity proofs which an inversion-derived solution gives you.
Of course if you use this trick, then you still (might) need to do by hand the equational pre-processing of families P which Epigram would do for you in more complex examples such as Vec_tail, where you need to do the equational reasoning to push a Vec n to a Vec m ... having simplified Sm = Sn to m = n etc.
It is true that a true 'dependent pattern matching' vernacular syntax would be very nice to have in Coq, ... so people have begun working on this. In the meantime, let the optional 'return' clause in match expressions be your friend...
Best wishes,
James McKinna
Dimitri Hendriks wrote:
for pattern matching over dependent types you
have to use an explicit elimination predicate
to predict the type of the righthand side.
see ch. 15 of the manual.
if you first ...
you can see what the predicate should look like:
(vec m) -> (m = S n -> A)
and this may insprire you to write for instance:
match v in (vec m) return (m = S n -> A) with
| Vnil => fun H => False_rect A (disc_O_S n H)
| Vcons a _ _ => fun _ => a
end (refl_equal (S n)).
dimitri
- [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors,
Dimitri Hendriks
- Re: [Coq-Club] Matching non-empty vectors, Dimitri Hendriks
- Re: [Coq-Club] Matching non-empty vectors, James McKinna
- Re: [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors, Matthieu Sozeau
Dimitri Hendriks
