- To: Michael Day <mikeday AT yeslogic.com>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Matching non-empty vectors
- Date: Fri, 28 Mar 2008 13:01:01 +0100
Le 28 mars 08 à 09:07, Michael Day a écrit :
Hi,
Hi,
I have defined a simple vector type and a function to get the first element of non-empty vectors as follows:
Inductive vec (A:Type) : nat -> Type :=
| Vnil : vec A 0
| Vcons : forall (a:A) (n:nat), vec A n -> vec A (S n).
Definition get_first (A:Type) (n:nat) (v:vec A (S n)) (default:A) : A :=
match v with
| Vnil => default (* I want to delete this line *)
| Vcons a _ _ => a
end.
Coq prevents me from calling get_first with an empty vector, so the Vnil case will never be matched and the default value will never be used. However, Coq does not permit me to omit this case:
Error: Non exhaustive pattern-matching: no clause found for pattern Vnil
This is incredibly frustrating. Why does Coq think that "Vnil" is an inhabitant of "vec (S n)"? After reading Conor McBride's papers on Epigram I expect the system to understand that 0 <> S n :)
The Vhead function in the Bvector module in the standard library uses the inversion tactic instead, but that seems to generate a very large and complicated definition for something that should be quite simple.
The reason for this complicated term is that exhaustiveness of pattern- matching with dependent types is an NP-complete problem [1], hence we can find no effective procedure to always decide exhaustiveness that could be used during typing. There are different ways to go around this:
- Epigram and Agda(s) have a kind of "best effort" algorithm that tries to derive as much information as possible from the type of the matched term and the patterns using first-order unification.
This permits to get rid of most(all?) of the innaccessible branches. However, to justify this fairly complicated algorithm, you have to prove that it can be "compiled away" to the core type theory [2]. The resulting compiled term will have more or less the same form as the one generated by the Coq tactics, using the propositional equality to carry information on the objects and patterns.
- Coq does nothing about it (yet), but can almost be used as a core theory (assembly) to compile higher-level pattern matching to. It needs to be extended with an axiom such as Streicher's K to be really a good target. There is ongoing work on adding K and inversion of pattern-matching in the kernel.
- Program/Russell does the compilation in Coq. It generates the equalities during pattern-matching and uses the existing proof machinery to try to derive contradictions in inaccessible branches.
For example you may write:
Require Import Coq.Program.Program.
Program Definition tail' (A:Type) (n:nat) (v:vec A (S n)) : vec A n :=
match v with
| Vnil => !
| Vcons _ n' v' => v'
end.
This will generate two obligations, one to prove that (S n = 0 -> False) and another to prove that (S n = S n' -> n' = n). You still have to give the inaccesible branches but that's only an engineering issue (it prevents finding out you have forgottoen a pattern only when trying to prove the obligations). The resulting term is ugly and somewhat hard to work with.
Regarding the trick of pattern-matching on the index in the clause, it seems you can go a long way, as this is accepted by Coq:
Definition tail (A:Type) (n:nat) (v:vec A (S n)) (default:A) : vec A n :=
match v in (vec _ m) return (match m with 0 => True | S n' => vec A n' end) with
| Vnil => I (* I want to delete this line *)
| Vcons _ _ v' => v'
end.
Also, False_rect is extracted to assert false, not a complicated computation :)
[1] N. Oury. Pattern matching coverage checking with dependent types using set approximations. In A. Stump and H. Xi, editors, PLPV, pages 47–56. ACM, 2007.
[2] H. Goguen, C. McBride, and J. McKinna. Eliminating dependent pattern matching. In K. Futatsugi, J.-P. Jouannaud, and J. Meseguer, editors, Essays Dedicated to Joseph A. Goguen, volume 4060 of Lecture Notes in Computer Science, pages 521–540. Springer, 2006.
-- Matthieu Sozeau
- [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors,
Dimitri Hendriks
- Re: [Coq-Club] Matching non-empty vectors, Dimitri Hendriks
James McKinna
- Re: [Coq-Club] Matching non-empty vectors, Michael Day
- Re: [Coq-Club] Matching non-empty vectors, Matthieu Sozeau
Dimitri Hendriks
