Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.
chronological Thread
- To: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- Cc: Adam Chlipala <adamc AT cs.berkeley.edu>, coq-club AT pauillac.inria.fr
- Subject: Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.
- Date: Sun, 13 Apr 2008 09:29:23 +0200
Theodoros G. Tsokos wrote:
Well, let me be more precise, as I think that my example wasn't the most appropriate one.What you are showing is still confusing as it looks to be not well-typed.
Assuming that I have *op_and* defined, as the logical operator between two terms b1 b2. Let *FF* be an inductive definition:
Inductive FF: env->term->type->Prop :=
| C4: forall G b1 b2, FF G b1 expr -> FF G b2 expr -> FF G (op_and b1 b2) expr
And assuming that in my Lemma, I want to prove the following subgoal:
G : env
b1: term
b2: term
v1: bool
v2: bool
t: type
H1 : FF G b1 t -> FF G v1 t
H2 : FF G b2 t -> FF G v2 t
FF G (op_and b1 b2) t -> FF G (v1 && v2) t
Is is possible to prove it? I think it should be, as I proved this lemma on paper properly.
Thanks again,
Theo.
Is there a coercion from bool to term? Are there other constructors in the definition of FF that conclude
with "op_and ..."?
Yves
- [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.,
Adam Chlipala
- Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.,
Theodoros G. Tsokos
- Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Yves Bertot
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
Theodoros G. Tsokos
Adam Chlipala
