- To: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.
- Date: Mon, 14 Apr 2008 08:37:57 +0200
Theodoros G. Tsokos wrote:
Yves Bertot wrote:Well, for lack of more information, I assume that op_and is also a constructor of the term type.
Theodoros G. Tsokos wrote:Yes, there is a coercion from bool to term after the definition of term:
Well, let me be more precise, as I think that my example wasn't the most appropriate one.What you are showing is still confusing as it looks to be not well-typed.
Assuming that I have *op_and* defined, as the logical operator between two terms b1 b2. Let *FF* be an inductive definition:
Inductive FF: env->term->type->Prop :=
| C4: forall G b1 b2, FF G b1 expr -> FF G b2 expr -> FF G (op_and b1 b2) expr
And assuming that in my Lemma, I want to prove the following subgoal:
G : env
b1: term
b2: term
v1: bool
v2: bool
t: type
H1 : FF G b1 t -> FF G v1 t
H2 : FF G b2 t -> FF G v2 t
FF G (op_and b1 b2) t -> FF G (v1 && v2) t
Is is possible to prove it? I think it should be, as I proved this lemma on paper properly.
Thanks again,
Theo.
Is there a coercion from bool to term? Are there other constructors in the definition of FF that conclude
with "op_and ..."?
Yves
Inductive term: Set :=
| term_bool (_ : bool)
Coercion term_bool : bool >-> term.
Also, there 're no other constructors in the definition of FF that conclude with "op_and ... ".
Trying not to bore you and not to have a huge email, I might be missing some important parts for your comprehension.
Regards,
Theo.
Starting from your goal:
H1 : FF G b1 -> FF G v1
H2 : ...
FF G (op_and b1 b2) -> FF G (v1 && v2)
I would simply use inversion, in the following way:
intros HA; inversion HA.
This would yield two hypotheses with statements:
FF G b1
and
FF G b2
and then it would be possible to conclude, by case analysis on v1 (tactic destruct), and
a second case analysis on v2 in the case where v1 is true.
Tell me if this helps.
Yves
- [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.,
Adam Chlipala
- Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.,
Theodoros G. Tsokos
Yves Bertot
Theodoros G. Tsokos
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Yves Bertot
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
Theodoros G. Tsokos
Yves Bertot
Theodoros G. Tsokos
Adam Chlipala
