Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.
chronological Thread
- From: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- To: Adam Chlipala <adamc AT cs.berkeley.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.
- Date: Wed, 09 Apr 2008 19:10:28 +0100
Adam Chlipala wrote:
I don't think your lemma is true, going on just the information you've provided so far. While you could prove the goal [f (v1 + v2)] from [f v1] and [f v2], the hypothesis of [f (a1 + a2)] does not imply [f a1] or [f a2], because a natural number can be decomposed into multiple distinct sums. (And this is ignoring the potential further confounding influences of the [f] constructors you haven't included.)Well, let me be more precise, as I think that my example wasn't the most appropriate one.
Theodoros G. Tsokos wrote:
Assuming I want to solve the following goal in a Lemma:
H1: f a1 -> f v1
H2: f a2 -> f v2
f (a1+ a2) -> f (v1+v2)
Where in the inductive definition of f, one of its constructors is:
Inductive f : ... :=
| Cx : forall x y, f x -> f y -> f(x+y)
Assuming that I have *op_and* defined, as the logical operator between two terms b1 b2. Let *FF* be an inductive definition:
Inductive FF: env->term->type->Prop :=
| C4: forall G b1 b2, FF G b1 expr -> FF G b2 expr -> FF G (op_and b1 b2) expr
And assuming that in my Lemma, I want to prove the following subgoal:
G : env
b1: term
b2: term
v1: bool
v2: bool
t: type
H1 : FF G b1 t -> FF G v1 t
H2 : FF G b2 t -> FF G v2 t
FF G (op_and b1 b2) t -> FF G (v1 && v2) t
Is is possible to prove it? I think it should be, as I proved this lemma on paper properly.
Thanks again,
Theo.
- [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal.,
Adam Chlipala
- Re: ?spam? Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
- Re: [Coq-Club] applying at the same time two hypothesis to solve a goal., Theodoros G. Tsokos
Adam Chlipala
