- To: Coq-Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Automatically unfolding simple definitions
- Date: Thu, 10 Jul 2008 15:11:56 +0100
- Organization: School of Informatics, The University of Edinburgh
Hi,
I'm writing some automated tactics and want to check if there is a reduction
tactic that can simplify the current goal in a certain way. It's sometimes
useful to use definitions as shorthands for common expressions e.g.
Definition permutation x y := forall n, count n x = count n y.
In my domain, it is normally required that all 'simple' definitions like this
(i.e. non-recursive functions) be unfolded first for my automation to work.
As a simple example of what I need, given this definition:
Definition f x y := plus x y.
The following is true:
Goal forall x y, f x y = f y x.
My proof automation can prove this goal but only if "f" is unfolded first.
I've tried various combinations to have this done automatically (i.e. I don't
want to have to tell it what to unfold explicitly) but I cannot find a
suitable reduction tactic. The closest I've found is compute which gives
this:
forall x y : nat,
(fix plus (n m : nat) : nat := match n with
| 0 => m
| S p => S (p + m)
end) x y =
| 0 => m
| S p => S (p + m)
end) y x
I can then "fold plus" to get the simplification I want:
forall x y : nat, x + y = y + x
However, I'd like a tactic that does this automatically. Is there a tactic
that can do unfolding like this without me having explicitly name
definitions? Perhaps there is a way to automatically fold up goals
containing "fix plus" like terms? Even a function only available in OCaml
would be suitable.
Thanks,
Sean
- [Coq-Club] The greatest common divisor in the standard library, Andrés Sicard-Ramírez
- Re: [Coq-Club] The greatest common divisor in the standard library, Johannes Waldmann
- [Coq-Club] Automatically unfolding simple definitions, Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions,
Adam Chlipala
- Re: [Coq-Club] Automatically unfolding simple definitions, Andrew McCreight
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Vladimir Komendantsky
- Re: [Coq-Club] Automatically unfolding simple definitions, Robin Green
Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Benjamin Gregoire
Adam Chlipala
