- From: Benjamin Gregoire <Benjamin.Gregoire AT sophia.inria.fr>
- To: Sean Wilson <sean.wilson AT ed.ac.uk>
- Cc: Coq-Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Automatically unfolding simple definitions
- Date: Fri, 11 Jul 2008 13:26:43 +0200
I think that you want a notation instead of a definition.
Require Import ZArith.
Open Scope Z_scope.
Definition Plus x y := x + y.
Notation "x 'PLUS' y " := (x + y) (at level 50).
Lemma PLUS_comm : forall x y, x PLUS y = y PLUS x.
intros;ring.
Qed.
Lemma Plus_comm : forall x y, Plus x y = Plus y x.
(*intros;ring.
Error: Tactic failure not a valid ring equation *)
intros;unfold Plus;ring.
Qed.
Best.
Sean Wilson wrote:
Hi,
I'm writing some automated tactics and want to check if there is a reduction tactic that can simplify the current goal in a certain way. It's sometimes useful to use definitions as shorthands for common expressions e.g.
Definition permutation x y := forall n, count n x = count n y.
In my domain, it is normally required that all 'simple' definitions like this (i.e. non-recursive functions) be unfolded first for my automation to work. As a simple example of what I need, given this definition:
Definition f x y := plus x y.
The following is true:
Goal forall x y, f x y = f y x.
My proof automation can prove this goal but only if "f" is unfolded first. I've tried various combinations to have this done automatically (i.e. I don't want to have to tell it what to unfold explicitly) but I cannot find a suitable reduction tactic. The closest I've found is compute which gives this:
forall x y : nat,
(fix plus (n m : nat) : nat := match n with
| 0 => m
| S p => S (p + m)
end) x y =
| 0 => m
| S p => S (p + m)
end) y x
I can then "fold plus" to get the simplification I want:
forall x y : nat, x + y = y + x
However, I'd like a tactic that does this automatically. Is there a tactic that can do unfolding like this without me having explicitly name definitions? Perhaps there is a way to automatically fold up goals containing "fix plus" like terms? Even a function only available in OCaml would be suitable.
Thanks,
Sean
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Automatically unfolding simple definitions, (continued)
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions,
Adam Chlipala
- Re: [Coq-Club] Automatically unfolding simple definitions, Andrew McCreight
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Vladimir Komendantsky
- Re: [Coq-Club] Automatically unfolding simple definitions, Robin Green
Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Benjamin Gregoire
Adam Chlipala
Sean Wilson
