- From: "Andrew McCreight" <continuation AT gmail.com>
- To: "Adam Chlipala" <adamc AT hcoop.net>
- Cc: "Sean Wilson" <sean.wilson AT ed.ac.uk>, Coq-Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Automatically unfolding simple definitions
- Date: Thu, 10 Jul 2008 07:26:41 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:cc:in-reply-to:mime-version :content-type:references; b=ThVSmiXCyNLtMW9RB5VM+Gpt/s/14DHE0UotxcMvz3HVPYVI5byJ76pd07b1QWiiHu 2s0FgbJIus7aSZ6zXjM0paC6gwEIm0EvsLGIW5FdGUwf3ETMCusOdXm4r9znydeHM6HL 0/HpR3RrFpRtMMbFrQnQUdJu+nhDNme9wtbqA=
A slightly different way to approach this would be to identify things you don't want to have unfolded using cbv:
cbv beta delta -[plus].
The drawback of this is that I can't think of any way (offhand) to compose more than one of these tactics, so you would have to define it once and for all.
On Thu, Jul 10, 2008 at 7:21 AM, Adam Chlipala <adamc AT hcoop.net> wrote:
Sean Wilson wrote:It seems dubious that you can even describe a general tactic for this kind of thing. [plus] is no more privileged as a "primitive definition" than your [f], as far as Coq is concerned. The heuristic you suggest for not unfolding recursive function definitions might work, but you might run up against a library function that you want to consider "primitive" that happens to be defined in terms of a recursive helper function, and then (if I understand you) the heuristic wouldn't do what you want.
As a simple example of what I need, given this definition:
Definition f x y := plus x y.
The following is true:
Goal forall x y, f x y = f y x.
My proof automation can prove this goal but only if "f" is unfolded first.
I recommend parameterizing your automation on a simplification tactic, which could just be an [unfold] with a long list of identifiers.
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] The greatest common divisor in the standard library, Andrés Sicard-Ramírez
- Re: [Coq-Club] The greatest common divisor in the standard library, Johannes Waldmann
- [Coq-Club] Automatically unfolding simple definitions,
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions,
Adam Chlipala
- Re: [Coq-Club] Automatically unfolding simple definitions, Andrew McCreight
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Vladimir Komendantsky
- Re: [Coq-Club] Automatically unfolding simple definitions, Robin Green
Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Benjamin Gregoire
Adam Chlipala
