- To: Coq-Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Automatically unfolding simple definitions
- Date: Fri, 11 Jul 2008 12:24:24 +0100
- Organization: School of Informatics, The University of Edinburgh
On Friday 11 July 2008 10:35:18 Stéphane Glondu wrote:
> Sean Wilson wrote:
> > Definition permutation x y := forall n, count n x = count n y.
> > In my domain, it is normally required that all 'simple' definitions like
> > this (i.e. non-recursive functions) be unfolded first for my automation
> > to work. As a simple example of what I need, given this definition:
> Have you tried "Hint Unfold permutation." after your definition?
Hi,
I was looking for a way for this to happen automatically without me having to
explicitly name definitions. It isn't a huge burden on the user to identify
such terms, but I wanted to remove the need for such hints if possible. I
suppose another approach is to have the machine identify definitions that are
suitable as unfold hints and automatically add them as unfold hints at the
point such definitions are entered into Coq. I could then use
Matthieu's "autosimpl" to unfold them.
Thanks,
Sean
- [Coq-Club] The greatest common divisor in the standard library, Andrés Sicard-Ramírez
- Re: [Coq-Club] The greatest common divisor in the standard library, Johannes Waldmann
- [Coq-Club] Automatically unfolding simple definitions,
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions,
Adam Chlipala
- Re: [Coq-Club] Automatically unfolding simple definitions, Andrew McCreight
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Vladimir Komendantsky
- Re: [Coq-Club] Automatically unfolding simple definitions, Robin Green
Stéphane Glondu
- Re: [Coq-Club] Automatically unfolding simple definitions, Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Stéphane Glondu
- Re: [Coq-Club] Automatically unfolding simple definitions, Benjamin Gregoire
Adam Chlipala
